Введение
In this guide, you will learn how to remove and replace the music button in the middle of the device
Выберете то, что вам нужно
Place the device face down on a flat surface, so that the screws on the back are facing the ceiling.
Using a screwdriver loosen the four screws connecting the body of the device together.
Gently pull the music button off and replace it with a new one. If you want to put a music button back in, the marked curve must line up with the one on the body.
