Bali Custom Blinds Replacement
Выберете то, что вам нужно
  1. Bali Custom Blinds Replacement, Blinds: шаг 1, изображение 1 из 1
    • Measure the window frame width.
    • This measurement will be used to buy your new replacement blinds.
    • Mark where the top center of your window frame is for future reference when installing the center support bracket.
    • Blinds are not supposed to fit noticeably tight into the window frame.
    • Leave an inch of room (half inch on each side) so it can hang properly within the installation brackets.
  2. Bali Custom Blinds Replacement: шаг 2, изображение 1 из 2 Bali Custom Blinds Replacement: шаг 2, изображение 2 из 2
    • Push the tabs on the installation brackets to loosen their hold on the blinds headrail.
    • Gently pull out the headrail to remove it from the installation bracket.
    • It is best to do these steps one at a time on each installation bracket.
  3. Bali Custom Blinds Replacement: шаг 3, изображение 1 из 3 Bali Custom Blinds Replacement: шаг 3, изображение 2 из 3 Bali Custom Blinds Replacement: шаг 3, изображение 3 из 3
    • Remove the screws that keep your installation brackets in place.
    • Remove the installation brackets. If there is a center support bracket, remove that as well.
    • Keep the screws. You may need them when we install the new blinds.
    • Once the old brackets are out, it may be necessary to drill new screws into your wall if your old screws do not match up with the new bracket.
  4. Bali Custom Blinds Replacement: шаг 4, изображение 1 из 1
    • Press the installation brackets up against each inner corner of the window frame.
    • Drill in the new brackets with the supplied screws.
    • While most brackets are installed in the furthest back corner of the window frame depth, some prefer them further out. You will need to measure between the brackets to make sure they are lined up properly.
    • If there is a center bracket, reinstall it to the previously marked center.
  5. Bali Custom Blinds Replacement: шаг 5, изображение 1 из 1
    • Insert each end of the headrail into the installation brackets while pressing down on the tabs.
    • If the blinds are too tight and cannot fit into the brackets, you may need to downsize your blinds by an inch.
  6. Bali Custom Blinds Replacement: шаг 6, изображение 1 из 2 Bali Custom Blinds Replacement: шаг 6, изображение 2 из 2
    • Make sure the blinds lower equally without catching on anything.
    • If the blinds do catch, you may need to reinstall the brackets and blinds.
Заключение
To reassemble your device, restart these instructions from the first step to the last step.
Tyler Shap
Участник с: 10/31/17
101 Репутация
1 руководство автора
Команда
DePaul University, Team S1-G3, Dush Fall 2017 Участник DePaul University, Team S1-G3, Dush Fall 2017
DPU-DUSH-F17S1G3
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 37
За всё время: 1,165
