Введение
Whether your blinds are old or just plain falling apart, this guide will help you easily replace headrail, installation brackets and blinds.
Please note that blinds do not fit exactly to the window frame. They must be mounted in installation brackets, so leave approximately an inch of wiggle room.
Выберете то, что вам нужно
Measure the window frame width.
Mark where the top center of your window frame is for future reference when installing the center support bracket.
Push the tabs on the installation brackets to loosen their hold on the blinds headrail.
Gently pull out the headrail to remove it from the installation bracket.
Remove the screws that keep your installation brackets in place.
Remove the installation brackets. If there is a center support bracket, remove that as well.
Press the installation brackets up against each inner corner of the window frame.
Drill in the new brackets with the supplied screws.
If there is a center bracket, reinstall it to the previously marked center.
Insert each end of the headrail into the installation brackets while pressing down on the tabs.
To reassemble your device, restart these instructions from the first step to the last step.
