Введение
This guide will instruct on how to replace an old bathroom faucet with a new one. One may need to replace a faucet if the taps stop working, there is rust or chemical damage, or even to beautify the bathroom.
Before following this guide, ensure the replacement faucet is the right pick for the sink it is being placed in. The replacement faucet in this guide is a MOEN Adler 4-inch Centerset Single-Handle Low-Arc Bathroom Faucet. The faucet being replaced is an older model of the same kind. Be wary that the instructions for alternative faucets may differ slightly. However, most faucets have similar parts so this guide will still be helpful.
Выберете то, что вам нужно
Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
After unscrewing the bolts, the faucet pipes should easily come off.
Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
Insert the pipes of the replacement faucet through the sink holes.
Each pipe will correspond to each hole on the right and left.
With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
Tighten the left and the right pipe.
Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
To remove the replacement faucet, follow steps 1-6.
