Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta"
Выберете то, что вам нужно
  1. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: шаг 1, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: шаг 1, изображение 2 из 2
    • Underneath the sink there are two valves that supply water to each knob. Turn off the supply by twisting the valves tightly to the right.
    • The water supply needs to be off before starting the replacement. Failure to do so can result in water spouting all over the area, causing damage.
  2. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 2, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 2, изображение 2 из 2
    • Double-check that the water supply is off by twisting the faucet knobs to the left.
  3. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 3, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 3, изображение 2 из 2
    • With the 1/8” flathead screwdriver, insert through the groove on the edge of the hot-n-cold caps, loosen, and remove them.
  4. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 4, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 4, изображение 2 из 2
    • Using the PZ1 starhead screwdriver, loosen the 19.1 mm oval head screw.
  5. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 5, изображение 1 из 3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 5, изображение 2 из 3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 5, изображение 3 из 3
    • Remove the 19.1 mm oval head screw by pulling it up from the knob.
    • Lift the knob from the faucet to remove it.
  6. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 6, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 6, изображение 2 из 2
    • Use an adjustable wrench to loosen the bonnet nut.
  7. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 7, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 7, изображение 2 из 2
    • Remove the bonnet nut from the faucet.
  8. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 8, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 8, изображение 2 из 2
    • Remove the escutcheon by pulling it out from the valve.
  9. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 9, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 9, изображение 2 из 2
    • Place the new escutcheon by pushing it down into the valve.
  10. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 10, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 10, изображение 2 из 2
    • Install the new bonnet nut by placing it over and around the escutcheon.
  11. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 11, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 11, изображение 2 из 2
    • Using an adjustable wrench, tighten the bonnet nut by twisting it to the right.
  12. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 12, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 12, изображение 2 из 2
    • Install the new knob by placing it on top and around the escutcheon and bonnet nut.
  13. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 13, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 13, изображение 2 из 2
    • Insert the 19.1 mm oval head screw into the top of the knob.
  14. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 14, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 14, изображение 2 из 2
    • Using the PZ1 starhead screwdriver, tighten the screw by twisting it to the right.
  15. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 15, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 15, изображение 2 из 2
    • Install the new hot-n-cold caps by snapping them onto the top of the knobs.
  16. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 16, изображение 1 из 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": шаг 16, изображение 2 из 2
    • Turn on the water supply by twisting the valves to the left.
Заключение
Test that the replacement was done correctly and that the water supply is on by twisting the faucet knobs to the right. Enjoy your new remodeled faucet!
Еще один человек закончил это руководство.
Benjamin Figueroa
Участник с: 09/23/23
295 Репутация
1 руководство автора
Команда
Austin Community College, Team 1-5, Watkins Fall 2023 Участник Austin Community College, Team 1-5, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G5
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 152
