Введение
It shows how the battery is removed....
Инструменты
No tools specified.
Запчасти
  1. These two pins must be removed.
    • These two pins must be removed.
  2. Here, a screwdriver or other stable thin object (in the picture: letter opener) can be helpful
    • Here, a screwdriver or other stable thin object (in the picture: letter opener) can be helpful
  3. TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary
    • TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary
  4. The panel is now dismantled
    • The panel is now dismantled
  5. These two pins must be removed
  6. TIP: Since this work has to be done more often, it is recommended to provide the cotter pins with some insulating tape so that they can be removed without tools
    • TIP: Since this work has to be done more often, it is recommended to provide the cotter pins with some insulating tape so that they can be removed without tools
  7. The battery holder can now be pulled off upwards
    • The battery holder can now be pulled off upwards
  8. Now the battery connection is disconnected
    • Now the battery connection is disconnected
  9. And the battery can be removed upwards And the battery can be removed upwards
    • And the battery can be removed upwards
  10. The battery can now be charged
    • The battery can now be charged
Заключение
Repeat the steps in order to reassemble your device.
Особая благодарность этим переводчикам:
100%
Israel is helping us fix the world! Хотите внести свой вклад?
Начните переводить ›
Leonard Kesting
Участник с: 14.08.2016
822 Репутация
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 77
