Введение
Prereq Only: Disconnect the battery in an iPhone 6s.
Инструменты
Запчасти
Детали не указаны.
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
Еще один человек закончил это руководство.
