Введение
This guide will walk you through the process of replacing the Main Power Receptacle in a Bear 1000 Ventilator. Found on page 89 in the full service manual.
Remove the ribbon cable at the connection on the oxygen blender control board.
Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
Remove the pneumatic and electrical connections labeled.
Note and mark the orientation of the wires. Remove the two wires going to the fuses at the fuse end and the ground wire going to the main ground stud.
