Введение
In this guide, the process of speaker replacement is shown.
Выберете то, что вам нужно
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Using your thumb, remove the 8 rubber plugs in order to get to the screws.
Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
After completing the guide for removing the case, remove the cables connecting the speakers.
Simply pull up on them without pulling on the wires themselves.
Using a Phillips #2 screwdriver, remove the 4 (8mm maxi-loc Phillips #2) screws holding the speaker to the case.
While holding the case with one hand, pull up on the speaker you wish to replace.
2 участников успешно повторили данное руководство.
5 Комментариев
Where can I find replacement speakers?
Please
Where can I find the replacement speakers..??
