Введение
Look at this guide if your Studio 3 Beats headphones are broken from one side or both. After a particular time, a piece of the headband, which keeps the headphones in the proper position, will break. It can be fixed by replacing the headband.
Выберете то, что вам нужно
Slide the headband down to reveal the the screws
Unscrew both screws from each side of the Headphones.
Get the new headband and snap back the cushion pad together.
Put back the foam pad together.
- locate screws and unscrew
- remove cushion, foam, and broken headband
- remove any broken plastic inside the clasps
- get the new headband and place it on the headphones; make sure the letter B is on the left and the S on the right of the headphones
- place foam and cushion with the headband. It will make a snapping noise if done correctly
- screw in the screws
3 участников успешно повторили данное руководство.
