Введение
Hey headphone enthusiasts! Ever faced that frustrating moment when your Beats Studio3 won't charge properly? Don't worry, I've got a quick fix for you. In this guide, I'll walk you through a simple repair for the common issue of a faulty charging port. All you'll need are some basic tools, a replacement part if necessary, and about 30 minutes of your time. It's a hassle-free process that's a lifesaver for those unexpected charging glitches that can happen over time. Stick with me, and we'll have your favorite headphones back to full power in no time!"
Выберете то, что вам нужно
Remove the pad that is on the charging port side using an opening tool.
Remove seven screws from the earpiece using a Phillips screwdriver.
Pry the top panel away from the rest of the speaker using an opening tool.
Use the soldering iron to carefully desolder five different wires from their respective points.
After disconnecting the wires, gently push the charger upward using your fingers to detach it from the base. Be careful to avoid damaging any components
Position the new charger by aligning it properly with the base. Push the new charger into place, ensuring it fits snugly and securely.
Reattach the five wires to their designated points on the new charger by soldering them securely. Ensure each wire is correctly connected to its corresponding point to guarantee proper functionality.
Еще один человек закончил это руководство.
