Введение
This guide explains how to replace the battery for BEBONCOOL Wireless Switch Pro Controller. Rechargeable batteries only have so many cycles of charge and discharge. When the battery is no longer able to be recharged this does not mean that the controller itself is bad, it simply means that a new, fresh battery is needed. This guide is written to help you replace the factory installed battery with a new one to continue to use your controller without having to buy a complete new one.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
Use a Phillips #0 screwdriver to remove the two 5 mm screws securing the battery.
