Bed Head Wave Artist Deep Waver Main Capacitor Replacement
Выберете то, что вам нужно
  1. Bed Head Wave Artist Deep Waver Main Capacitor Replacement, Lower Handle Housing: шаг 1, изображение 1 из 2 Bed Head Wave Artist Deep Waver Main Capacitor Replacement, Lower Handle Housing: шаг 1, изображение 2 из 2
    • Before disassembling your Deep Waver, be sure to unplug the device to avoid electric shock, and make sure the heating elements of the device are cool to avoid burns.
    • Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
    • Remove two 10 mm Phillips #01 screws from the lower handle housing.
    • Remove one 10 mm Phillips #02 screw from the lower handle housing.
  2. Bed Head Wave Artist Deep Waver Main Capacitor Replacement: шаг 2, изображение 1 из 1
    • Pry the black screw cover off the side of the lower handle housing using a fine-point spudger or pick. This side will have the model number and other product information embossed on it.
  3. Bed Head Wave Artist Deep Waver Main Capacitor Replacement: шаг 3, изображение 1 из 1
    • Remove one 10 mm Phillips 1 screw from the handle joint.
  4. Bed Head Wave Artist Deep Waver Main Capacitor Replacement: шаг 4, изображение 1 из 1
    • Pry the black screw cover off the other side of the lower handle housing. This side will have the power switch located on it.
  5. Bed Head Wave Artist Deep Waver Main Capacitor Replacement: шаг 5, изображение 1 из 1
    • Cut along the length of the black housing retainer with a rotary tool to split and remove the retainer.
  6. Bed Head Wave Artist Deep Waver Main Capacitor Replacement: шаг 6, изображение 1 из 1
    • Split the lower handle housing apart using a plastic opening tool.
    • Begin splitting the housing at one end rather than the center to avoid cracking the casing.
  7. Bed Head Wave Artist Deep Waver Main Capacitor Replacement, Main Capacitor: шаг 7, изображение 1 из 2 Bed Head Wave Artist Deep Waver Main Capacitor Replacement, Main Capacitor: шаг 7, изображение 2 из 2
    • Apply heat to both terminals of the capacitor with a soldering iron until the solder begins to melt.
    • Gently pull on each leg of the capacitor once the solder has began to melt to remove the wire from the circuit board.
Заключение
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
Grant Peters
Участник с: 11/06/17
401 Репутация
Автор 4 руководств
Команда
IUPUI, Team S6-G3, Baechle Fall 2017 Участник IUPUI, Team S6-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G3
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 379
