Введение
It is notable that after a long time, bed boards will start to get old or fold, due to the repeatedly use, and because of this, this guide has been provided if repair is need to be done, and you don’t have sufficient funds so you can just replace the boards with materials you already have and with a very quick repair the bed will be just like new.
In this guide you have been provided with the materials and procedure needed for you to complete the repair and assemble the replacement boards.
In order to repair these bed boards no prior experience is needed, you just need a few tools and to follow the instructions as clear as they are provided.
Note: Keep in mind that you are going to use tools so be careful, and remember that the matress and box spring may be heavy so you should consider having another person to help you if needed.
Выберете то, что вам нужно
Using your measure tape, measure the old boards and write down the measurements.
Find some wooden boards with 2x2 measures (width) and with the length you already measured.
To assemble your bed boards just follow the steps provided in the order given and your bed boards will be ready to go.
Еще один человек закончил это руководство.
