Введение
This guide requires you to use a soldering iron that can be dangerous if you do not know how to use it. I suggest looking at iFixit's Soldering Guide.
Выберете то, что вам нужно
Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
To remove the light, use a soldering iron to heat the solder to a liquid and loosen the leads.
While the solder is liquid, lightly pull on the LED to remove it from the motherboard.
