Введение
This guide will show you how to replace a capacitor on a Beko DHR73431W Heat Pump Dryer. This can fix issues with the barrel not turning.
Выберете то, что вам нужно
unscrew the 5 Phillips #2 cross-head screws for the side panel
Remove the 1 Phillips #2 cross-head screw on the bottom
Remove the 2 Phillips #21 cross-head screws from the top
Remove the 1 Phillips #2 cross-head screw for the capacitator that says 8 on it
Remove the two connectors on the side of the capacitor
To continue, put in your new capacitor then follow the steps in reverse.
Еще один человек закончил это руководство.
