Введение
If your Belkin Bluetooth keyboard (model F5L114) is not responding, a battery replacement may be needed.
Batteries do not last forever, even rechargeable ones. Replacing the battery renews the life of the keyboard for many more years keeping it out of landfills.
Before starting, make sure that the battery is a possible issue. Use different chargers to test that a faulty charger is not the case. If no charger makes the keyboard turn on, the charging port on the device could be the issue.
Before beginning, make sure to unplug anything connected to the keyboard.
Выберете то, что вам нужно
Switch the power button that is located at the bottom left of the keyboard to Off.
Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
Insert the spudger into the space next to the right screw area.
Gently pry open the battery case.
Еще один человек закончил это руководство.
Один комментарий
Hi, I would like buy another battery for my keyboard. May you help me please?
