Введение
This guide will walk you through how to replace the front casing on the NetCam.
Выберете то, что вам нужно
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Work a plastic opening tool into the seam and pry the face plate away from the back panel.
Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
