Выберете то, что вам нужно
Remove the five 30mm Phillips #0 screws on the bottom of the camera.
Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
Pull the side with the hand strap upwards to disconnect it from the camcorder.
Unscrew the four 40 mm Phillips #0 screws.
Add the new hand strap now.
