Введение
In this guide, the goal is to show how to take apart a Bell and Howell DNV16HDZ camcorder in order to replace parts such as the front LED. This would be helpful in the case of a damaged or malfunctioning LED in the camcorder. In this repair guide every screw was taken out using the Philips head #0 driver which is quite small. Also every screw taken out is the same uniform size (2mm) which is quite convenient.
Выберете то, что вам нужно
Remove the five 30mm Phillips #0 screws on the bottom of the camera.
Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
From here we can pop out the LED using the wedge or your fingers if you can manage it.
