Введение
This guide shows how to completely disassemble the Bella KitchenSmith 2 Slice Toaster 12082. Before beginning the disassembly, make sure that your toaster is not plugged into the wall - you don’t want to get electrocuted while you’re doing your disassembly. While you are doing the disassembly make sure to treat your toaster with respect - the toaster contains a circuit board which could be damaged if you are not careful.
Выберете то, что вам нужно
Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
Using the Triangle #2 screwdriver, remove four 100.0 mm screws from the base of the toaster.
Remove the bread holder base from the toaster by lifting it up and then pulling it towards you.
Unfold the two tabs on the top of the toaster that hold the central bar in place.
Lay the tray back down to its resting position and then pull the tray up and away from the device.
Pull the bottom of the side panels out and over the inner toaster pieces that are holding them in place.
Then completely remove both side panels.
Using the Phillips #1 screwdriver, remove the two 8.0 mm screws from the backside of the toaster.
2 участников успешно повторили данное руководство.
