Введение
Use this guide to replace the fan motor in your Bella Pro Series Air Fryer TXG-FS075A
The motor is what creates the movement of the fan. If this becomes faulty, it can cause the fan to slow down or not spin at all, which can cause food to not cook thoroughly.
Before using this guide, make sure to review the trouble shooting Bella TXG-FS075A troubleshooting guide here.
Выберете то, что вам нужно
Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
Pry off the black plastic frame.
Remove the four 13mm screws using a Phillips #2 screwdriver.
Slowly lift up and remove the motor.
