Введение
Is your speaker not working but still holding a charge? It's probably your motherboard. Follow this guide to replace it.
Выберете то, что вам нужно
Peel the rubber cover back from the corner of the speaker to reveal the screw.
Repeat for the three remaining corners.
Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
Lift the bottom cover away from the rest of the speaker.
Using the tweezers, pull the wires from the speaker's internal chip.
3 участников успешно повторили данное руководство.
