Введение
Is your charging base not functioning correctly? It's probably the motherboard.
Выберете то, что вам нужно
Peel the rubber cover back from the corner of the auxiliary charging base to reveal the screw.
Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the auxiliary charging base.
Using the plastic opening tool, gently pry the motherboard up and remove it from the charging base.
