Введение
This guide will display a step-by-step process on how to repair and replace your Besta Super 5000 keyboard. There is no special equipment or training needed in order to complete the replacement of your keyboard. Working with electrical equipment can always be hazardous, so remember to check the warnings of each step to ensure your safety as well as the integrity of your keyboard.
Выберете то, что вам нужно
Place your fingers on the battery cover arrow and pull the cover down and off the device.
Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
Еще один человек закончил это руководство.
