Введение
So, for this guide I will take you through the entire process of changing your bicycle grips. The included materials are listed, and there are some alternative methods discussed in here as well. Overall, the process is very simple. This guide shouldn't be very difficult at all.
Выберете то, что вам нужно
Put the straw of the air canister under the grip.
Pinch the end (can be done with pliers), and use the gap created to slip the straw in.
To separate the grip, you may use a screwdriver or another long, skinny tool allowing you to gain leverage underneath the grip.
While spraying air underneath the grips, pull on the grips with enough force to move them off the handlebar.
The air will separate the grips from the handlebars.
Spray the handlebar and inside the grip with your hairspray or lubricant/adhesive.
Slide the grips all the way on until there's no more room for the grips to slide on.
Slide the new grips on.
Let them dry.
Put your brakes and shifting levers back on.
Finally, enjoy the new grips!
In order to move or replace these grips follow these steps from top to bottom.
