Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement
Выберете то, что вам нужно
  1. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement, Rubber Grips on the Handlebars: шаг 1, изображение 1 из 1
    • Put the straw of the air canister under the grip.
    • Pinch the end (can be done with pliers), and use the gap created to slip the straw in.
    • To separate the grip, you may use a screwdriver or another long, skinny tool allowing you to gain leverage underneath the grip.
    • While spraying air underneath the grips, pull on the grips with enough force to move them off the handlebar.
    • The air will separate the grips from the handlebars.
    • If more force is needed, you may use an air compressor with a needle attachment.
  2. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: шаг 2, изображение 1 из 2 Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: шаг 2, изображение 2 из 2
    • Spray the handlebar and inside the grip with your hairspray or lubricant/adhesive.
    • Slide the grips all the way on until there's no more room for the grips to slide on.
    • I use hairspray because it is both a lubricant and an adhesive. Other combos can be WD-40 and super glue.
    • If your handlebar is dirty or you want to clean it, use warm soap and water to clean it with a wash cloth.
  3. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: шаг 3, изображение 1 из 1
    • Slide the new grips on.
    • Let them dry.
    • Put your brakes and shifting levers back on.
    • Finally, enjoy the new grips!
Заключение
In order to move or replace these grips follow these steps from top to bottom.
Phoenix Gavin-Scott Hanks Jr.
Участник с: 02/04/19
97 Репутация
1 руководство автора
Команда
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 830
