Bicycle chainring replacement
Выберете то, что вам нужно
  1. Bicycle chainring replacement, Chainring: шаг 1, изображение 1 из 1
    • Unscrew both nuts on opposite sides of the rear wheel with the 15 mm wrench until the wheel loosens from the bike frame.
    • Loosen the nuts with the 15 mm wrench and continue unscrewing the nuts with your hands.
    • Push the rear wheel forward until enough slack is given on the chain.
  2. Bicycle chainring replacement: шаг 2, изображение 1 из 2 Bicycle chainring replacement: шаг 2, изображение 2 из 2
    • With the slack previously made, remove the chain off the chainring.
    • Touching the chain isn't dangerous, but it will be dirty.
  3. Bicycle chainring replacement: шаг 3, изображение 1 из 2 Bicycle chainring replacement: шаг 3, изображение 2 из 2
    • Locate chainring, the gear connected to the pedals.
    • Place the spanner tool on the backside of the 6.5 mm chainring bolt. The spanner will be used to keep the bolts in place while unscrewing them on the opposite sides.
    • On the chainring there will be one bolt facing the opposite direction, usually the bolt blocked by the pedal. Adjust for this by swapping use of the hex key and spanner tool.
  4. Bicycle chainring replacement: шаг 4, изображение 1 из 1
    • With the spanner tool on one side of the chainring, use a 5 mm hex key to remove the chainring bolts on the opposite side.
    • Repeat with the rest of the bolts.
  5. Bicycle chainring replacement: шаг 5, изображение 1 из 1
    • Use clean paper towels to wipe off the chainring bolts. Make sure to wipe off all the dirt and grease you can.
    • Clean thoroughly within the threads.
  6. Bicycle chainring replacement: шаг 6, изображение 1 из 1
    • Now that the chainring bolts are clean, apply a pea-sized amount of grease to each bolt.
  7. Bicycle chainring replacement: шаг 7, изображение 1 из 1
    • Use your fingers to evenly spread a coat the grease around the entire bolt.
    • If the chainring bolts contain rust, it is recommended to replace the bolts with a new set.
Заключение
6 участников успешно повторили данное руководство.
Jeffrey Tang
Участник с: 02/24/15
391 Репутация
1 руководство автора
Команда
Cal Poly, Team 23-5, Green Winter 2015 Участник Cal Poly, Team 23-5, Green Winter 2015
CPSU-GREEN-W15S23G5
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 12
За последние 30 дней: 22
За всё время: 2,961
