Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
A damaged flex hose on your Bissell OptiClean Cyclonic Vacuum could be a reason that suction power is lost or low. If this is the case, it will be necessary to replace the damaged flex hose with a new one. This guide will teach you how to detach and replace the flex hose with handle on your Bissell OptiClean Cyclonic Vacuum.
  1. Grab hold of both the flex hose handle  and the extension wand. Pull straight out to detach the handle from the extension wand.
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  3. Locate the lock clip on the other end of the flex hose.
    • Locate the lock clip on the other end of the flex hose.
  4. Hold down the lock clip to unlock the flex hose from the vacuum. Remove the flex hose from the vacuum.
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
Заключение
Devin Rojo-Cagadoc
Участник с: 18.01.2018
97 Репутация
1 руководство автора
Команда
Cal Poly, Team S12-G1, Banghart Winter 2018 Участник Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 91
