Введение
The Bissell Pet Hair Erasers motherboard is accessible using this guide. This guide will show you how to replace the motherboard.
Выберете то, что вам нужно
Firmly grasp the handle and press the release button.
Gently pull the dirt cup down and away from the vacuum body.
Grasp each half of the body and gently pull apart.
Once the case is split apart these items may come dislodged.
Remove the battery plastic hold down by lifting it off the tabs.
Remove the battery by lifting straight up.
Position the battery aside.
Grasp the charger port and remove it by lifting it straight out of the case.
Set the charger port next to the battery.
Remove the power button and charge LED light by gently pulling straight out of the case.
The vacuum motor can be removed by pulling straight out of the case.
All internals are now removed.
Set the case halves aside.
Еще один человек закончил это руководство.
