Введение
This guide shows the users how to replace the Bissell PowerForce Compact vacuum belt using the tools and parts listed in this guide.
Выберете то, что вам нужно
Lift off the brush plate by grabbing both ends of the plate and lifting the plate up.
Grab the rotating brush at both ends.
Lift the rotating brush straight out of the vacuum.
Remove the belt from the motor pulley.
Clear the bottom of the vacuum from any debris that may be blocking air flow.
Clean the rotating brush from any wrapped string or hair. You can use scissors if needed.
Check the new belt for any damage.
Place the belt on the rotating brush and then the motor pulley.
Pull the rotating brush with the belt hooked.
Place the ends of the rotating brush into the slots.
Rotate the brush a few times to center the belt.
4 участников успешно повторили данное руководство.
