Введение
A quick debris canister funnel replacement guide for the Bissell Powerglide Cordless vacuum cleaner.
Выберете то, что вам нужно
Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
Remove the bottom of the assembly.
Twist the blue parts counterclockwise with a good amount of force to remove them.
