Введение
Is the water tank on your Bissell SpotClean ProHeat 5207U leaking? It could be because of a failing float gasket. Follow this guide to replace the float gasket on your Bissell SpotClean ProHeat 5207U .
Выберете то, что вам нужно
Position the device so that you can see the text at the bottom saying "SpotClean ProHeat."
Remove the dirty water tank located to the right.
Rotate the bottom of the flow stack counterclockwise until the float stack comes loose.
Remove the float stack from the tank.
3 участников успешно повторили данное руководство.
