Bissell SpotClean ProHeat 5207U Hose Replacement
Выберете то, что вам нужно
  1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: шаг 1, изображение 1 из 2 Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: шаг 1, изображение 2 из 2
    • Ensure Bissell SpotClean ProHeat is unplugged
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank and the clean water tank that are located on either side.
  2. Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 2, изображение 1 из 3 Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 2, изображение 2 из 3 Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 2, изображение 3 из 3
    • Turn the device so that the bottom is facing up.
    • Remove the marked 19.7 mm screws using the Phillips #00 screwdriver to remove the plastic covering.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three screws located under the plastic cover that was previously removed.
  3. Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 3, изображение 1 из 2 Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 3, изображение 2 из 2
    • Remove the plastic lip that was previously held by the screws.
    • Remove the 17.2 mm screws using the Phillips #00 Screwdriver to gain access to the water pump.
  4. Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 4, изображение 1 из 2 Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Use the tweezers to to squeeze together the prongs of the hose clamp.
    • With the clamp squeezed, pull the hose from the pump.
    • We found it easier to pull the clamp up the hose then pull the hose from the pump.
  5. Bissell SpotClean ProHeat 5207U Hose Replacement: шаг 5, изображение 1 из 1
    • Pull the hose from the opposite end of the pump until it is fully removed.
    • Replace the previous non-working hose with a new working hose.
Заключение
3 участников успешно повторили данное руководство.
Zachary Chandler
Участник с: 09/13/23
369 Репутация
Автор 2 руководств
Команда
University of North Texas, Team 6-4, Kilpatrick Fall 2023 Участник University of North Texas, Team 6-4, Kilpatrick Fall 2023
UNT-KILPATRICK-F23S6G4
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 21
За последние 30 дней: 109
За всё время: 385
