Введение
Is your Bissell SpotClean ProHeat 5207U spray trigger difficult to use? It could be because of a failing spray mechanism. Follow this guide to replace the spray mechanism for your Bissell SpotClean ProHeat 5207U.
Выберете то, что вам нужно
Place the brush in front of you and make sure that the brushes are rotated towards the ceiling.
Separate the brush from the hose by pressing the lever.
Using a Phillips screwdriver, unscrew the two 12.8 mm screws on the lever cap.
Remove the cap on top of the spring mechanism.
Grab the spraying mechanism and separate it from the lever by pulling it back.
Rotate the spraying mechanism clockwise to fully separate it.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, squeeze the hose clamp prongs together to loosen it.
As you are squeezing the hose clamp prongs, pull the spraying mechanism out to remove it.
Once the spraying mechanism is removed, and squeeze the clamp prongs again and install the new mechanism.
2 участников успешно повторили данное руководство.
