Введение
The device's power cord breaks easily, so it is important to be able to install a new one. In this guide we will learn how to replace the device's power cord.
Выберете то, что вам нужно
Turn the device upside-down, so that the four legs of the device point upwards.
Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
Unscrew the screw at the junction near the opposite side of the device from the front panel.
Label each of the two wires at this junction with a single color of tape.
Unscrew the screw at the junction just clockwise from the button panel.
Label the three wires of this junction with tape of a second color.
Unscrew the screw from the wire junction just behind the front panel.
Label the three wires at this junction with a third color of tape.
Plug the device's power cord into a functioning outlet.
Locate the two wires which are connected directly to the power cord. Unlike the other wires, they are sheathed in a particularly thick, dot-textured plastic.
Make sure the voltmeter is on and set to a setting beween 120 and 500V. For most voltmeters the proper setting for this is the 200V setting.
Attach one of the voltmeter's probes to the metal portions of each of the two wires connected to the power cord's end on the device
The voltmeter should read a number significantly above 20V. A reading between 100 and 150 V indicates that the device is getting enough power. A lower number indicates the power cord is broken.
Using a pair of pliers, pull the white plastic knob on the edge of the device up, away from the device. The knob should come lose.
Locate the small white latch on the side of the knob and pull it away from the cord. This will unlock it and expose he cord underneath. Set the knob aside.
Using a pair of scissors , cut the zip tie that holds the thick power supply wire to a smaller wire.
Pull the wires out through the hole, isolating the power cord from the device.
Replace with new power cord by doing disassembly steps in reverse order.
