Введение
I only like to use electric screwdrivers for the assembly of larger screws from larger components. This one has been used on many TV's and Radio's and just did not hold a charge any longer. I decided to get a new battery and replace the old one. Fairly easy and straight forward task. The biggest problem with this job was to find a new battery.
Выберете то, что вам нужно
Black & Decker 9074 type 4 screwdriver that no longer holds a charge.
Main pieces to work on for disassembly
Remove the clip that holds the transmission to the body. Insert a 6mm (1/4") flat tip screwdriver underneath the clip, gently move clip upward.
Once the clip is removed the transmission can be pulled of the body.
Move transmission away from body
Planetary gears inside the transmission look clean and complete.
Remove plastic washer that is situated between the transmission and the body.
These are the three screws that need to be removed.
Use a Phillips #1 screwdriver on those three screws
Three Phillips screws 7/8" long removed.
Separate the two body halves.
Battery, charging port and motor are clearly seen. These are just laid into the bottom half and can be easily removed.
The motor is held to the contact carrier by two elongated contacts. Clearly visible is a charging Diode as we as plenty of corrosion on the positive contact.
Remove motor by simply pulling it away from the contact carrier
View of the wiring with motor removed.
Top view of the wiring.
Use small needle nose pliers to remove cable connector from positive contact of the battery.
Positive wiring removed from battery.
Remove the negative (bottom) wire from battery. Gently pull it off the cable connector. Hold the wire close to the connector for removal.
All wiring separated from the battery. It is now ready to be replaced.
These are all the parts disassembled for this job.
9 участников успешно повторили данное руководство.
2 Комментариев
thanks. It is also useful for old TYPE 1 model 9018. But where can you find the battery?
Biller koby of course like so many other things, the battery is no longer available. But we have a fix for that as well. Check this guide Repairing Black and Decker 9074 Screwdriver Battery
