Black and Decker BDEDMT Circuit Board Replacement
Выберете то, что вам нужно
  1. Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: шаг 1, изображение 1 из 2 Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: шаг 1, изображение 2 из 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: шаг 2, изображение 1 из 3 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: шаг 2, изображение 2 из 3 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: шаг 2, изображение 3 из 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: шаг 3, изображение 1 из 2 Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  4. Black and Decker BDEDMT Circuit Board Replacement: шаг 4, изображение 1 из 3 Black and Decker BDEDMT Circuit Board Replacement: шаг 4, изображение 2 из 3 Black and Decker BDEDMT Circuit Board Replacement: шаг 4, изображение 3 из 3
    • There will be one black wire, a thin white wire and a thin red wire connecting to the trigger module from the circuit board. Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
    • Make sure to aim the tweezers toward the wire.
    • Lift the end of the tweezers to release the wire.
    • The Circuit board is now free.
    • Do not force the removal of the wire.
    • Remember to reinsert the wires to their corresponding slots when reassembling.
Заключение
Edgardo Gutierrez Jr
Участник с: 01/27/16
329 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-2, Rose Winter 2016 Участник UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 724
