Black and Decker BDEDMT Directional Switch Replacement
Выберете то, что вам нужно
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: шаг 1, изображение 1 из 2 Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: шаг 1, изображение 2 из 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: шаг 2, изображение 1 из 3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: шаг 2, изображение 2 из 3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: шаг 2, изображение 3 из 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: шаг 3, изображение 1 из 2 Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: шаг 3, изображение 2 из 2
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: шаг 4, изображение 1 из 2 Black and Decker BDEDMT Directional Switch Replacement: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: шаг 5, изображение 1 из 2 Black and Decker BDEDMT Directional Switch Replacement: шаг 5, изображение 2 из 2
    • The black directional switch can now be freely removed.
Заключение
Tyler Yurina
Участник с: 02/01/16
419 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-2, Rose Winter 2016 Участник UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 369
