Black and Decker BDEDMT Trigger Device Replacement
Выберете то, что вам нужно
  1. Black and Decker BDEDMT Trigger Device Replacement, Detach Matrix Attachment: шаг 1, изображение 1 из 2 Black and Decker BDEDMT Trigger Device Replacement, Detach Matrix Attachment: шаг 1, изображение 2 из 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: шаг 2, изображение 1 из 3 Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: шаг 2, изображение 2 из 3 Black and Decker BDEDMT Trigger Device Replacement, Remove Mounting Hardware: шаг 2, изображение 3 из 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Trigger Device Replacement, Trigger Device: шаг 3, изображение 1 из 1
    • Grab a hold of the trigger module. Gently lift the module out of the armature.
    • Be gentle with the module to ensure that the reverse switch is unaffected.
  4. Black and Decker BDEDMT Trigger Device Replacement: шаг 4, изображение 1 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 4, изображение 2 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 4, изображение 3 из 3
    • Simply roll the trigger module onto its back.
    • Located on on the bottom left of the module there will be a screw with the label 3.
    • Use your a JIS 0 screwdriver. After the screw is released, gently pull out the black wire.
    • The power cord is released from the trigger module.
  5. Black and Decker BDEDMT Trigger Device Replacement: шаг 5, изображение 1 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 5, изображение 2 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Located on the bottom side there will be a labeled area with a number 2. Below the two there will be a short white wire.
    • Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
    • Make sure aim the tweezers toward the wire.
    • Lift the end of the tweezers to release the wire.
    • Do not force the removal of the wire.
  6. Black and Decker BDEDMT Trigger Device Replacement: шаг 6, изображение 1 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 6, изображение 2 из 3 Black and Decker BDEDMT Trigger Device Replacement: шаг 6, изображение 3 из 3
    • Located on the top of the trigger module you will see four more wires entering the module. There will be two thin black wires, a thin white wire and a thin red wire.
    • The steps for the removal of these four wires is the same as seen in step number five.
    • Remember to reinsert the wires to their corresponding slots when reassembling.
    • The trigger module is now completely free from the rest of the device and can be replaced.
Заключение
cayla dahl
Участник с: 02/01/16
247 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-2, Rose Winter 2016 Участник UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 1,067
