Введение
This guide describes how to replace the holder brush and spring assembly from the BLACK and DECKER BDERO100 5 inch sander. You will need the JIS - J1 bit driver or equivalent, TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
Выберете то, что вам нужно
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
Separate both sides and open the device.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
With yout hands, hold and separate the power button from the external case by pulling gently.
Remove the wire connected to the brush holder from the motor by pulling gently.
Еще один человек закончил это руководство.
