Введение
Sometimes, the power switch can become jammed or broken. This guide will show how to take the housing apart and replace the power switch within the Black and Decker BDH9600CHV.
One thing to be aware of would be that the screws are deep within the outside of the housing so an extender could be needed to reach the screws
Выберете то, что вам нужно
To remove the filter and housing, press the green button labeled "Filter".
Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
Еще один человек закончил это руководство.
