Выберете то, что вам нужно
Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
Remove the following screws that secure the top and bottom halves of the base.
One 1/4 Phillips screw
One TA-20 screw
Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Once you have the base removed, the circuit board should be clearly visible inside.
Remove the four screws located on the circuit board.
Two are on the left side.
Two are on the right side.
Remove the following soldered connections with a soldering iron:
Motor wires
Power cord wires
Еще один человек закончил это руководство.
