Введение
The water pipes may become clogged, dirtied, or damaged to the point where they have to be removed and cleaned, or replaced entirely. This guide will show the steps to the disassembly process.
Выберете то, что вам нужно
Place your finger, screwdriver, or spudger behind the corner of the tab.
Pull up on the tab until it disconnects from the coffee maker.
Hold the tab while pushing back on the lid.
The lid should open fully with the top of the lid facing down.
Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
Pry facing away from the lid to force the peg out.
Hold the lid and pull it away from the other insert.
Place coffee maker on its side, with the bottom facing you.
Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
Slowly pry bottom lid from the front.
Pull up and remove the bottom lid and set aside.
Remove the four 10mm Phillips #1 screws.
Slowly pull the water tank up to expose the water pipes.
Squeeze and hold with tweezers again.
Pull the water tubes off the heating element while squeezing with tweezers.
