Введение
This guide will cover the removal and replacement of the circuit board of the DCM100R coffee maker line. This guide is intended to resolve the issues of inconsistent programming and faulty buttons. Before continuing with this guide review the trouble shooting page for possible fixes.
Выберете то, что вам нужно
Turn the coffee maker on its side.
Remove the four 6 mm Phillips #2 that secure the baseplate.
Apply pressure to the backside of the panel until it releases.
Remove the plate.
Remove the two 10 mm Phillips #2 screws securing the metal support brace.
Remove the brace and set aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull back the tubing and wiring to reveal the hot plate.
Use a Phillips #2 screwdriver to remove the five 8 mm screws that secure the mounting bracket and hot plate.
Remove the hot plate from the mounting bracket.
Remove the O-ring from the hot plate.
Remove the two 6 mm Phillips #2 screws that secure the circuit board.
