Введение
This guide will show you how to replace the heating element of the Black and Decker DCM100 Coffeemaker line. The guide is intended to help resolve water not warming to the desired temperature or at the expected speed. Before starting this guide, please see the trouble shooting page to help fix any other possible issues first.
Выберете то, что вам нужно
Turn the coffee maker on its side.
Remove the four 6 mm Phillips #2 that secure the baseplate.
Apply pressure to the backside of the panel until it releases.
Remove the plate.
Remove the two 10 mm Phillips #2 screws securing the metal support brace.
Remove the brace and set aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull back the tubing and wiring to reveal the hot plate.
Use a Phillips #2 screwdriver to remove the five 8 mm screws that secure the mounting bracket and hot plate.
Remove the hot plate from the mounting bracket.
Remove the O-ring from the hot plate.
