Введение
The nozzle brush located on the end of shaft may break off during the cleaning process. Replacing the brush is as easy as breaking it off.
Выберете то, что вам нужно
Rotate the free leg forwards or backwards from the hole.
This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
Check each leg hole for debris and clear whats needed.
Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
Slide the other leg into its respective hole.
