Введение
The motor compartment is located on the bottom of the juicer. In this compartment there are many wires. Make sure the machine is off and unplugged before accessing the compartment. Use caution when working with the wires as electric shock can happen.
Выберете то, что вам нужно
To replace the motor compartment, first follow the Disassembly Guide here
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
Unscrew the 19.1 mm screws inside the juicer holding the motor compartment attached to the juicer. Use the 2.5 mm Flathead adapter as the screw driver. The diameter of the screw head is 7.1 mm.
4 участников успешно повторили данное руководство.
