Введение
If your Black and Decker JS660 jigsaw is cutting but not cutting at the angle you desire. Make sure your angle lock is on not loose. If it continuous then you might need to change the angle lock. Use this guide to replace the angle lock on a Black and Decker JS660 jigsaw. The angle lock is a piece of the tool that allows you to cut at angle without worrying about messing up the angle of your cut. This guide will help you and show you how to replace the angle lock in 4 easy steps to cut the angles you want.
For this guide you will need a screwdriver to unscrew the screws and your new base and angle lock to replace the old before you start.
Before starting this guide, make sure your jigsaw isn't plugged into any outlet and is on a flat surface to work on.
Выберете то, что вам нужно
Use a screwdriver to remove the first screws securing the base to the jigsaw.
Remove the second screw.
Remove the base of the jigsaw.
With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
Remove the screw marked and the lever will slide out easily
The black screw must next be removed.
After removing the screw the lever will slide out of the jigsaw.
