Введение
If the chuck is jammed or not tightening up; the guide will illustrate a step by step process to help solve the problem.
Выберете то, что вам нужно
Gently grab both sides of the drill casing, and separate both sides from each other.
After following the prerequisite, the drill is now open.
The interior components can now be accessed.
The three metal tips in the front are the ones that are controlled by the chuck to hold and release the screw.
To test the chuck twist the head as shown in the illustration.
If the three metal tips don't move upon twisting then the chuck isn't working effectively and will need to be replaced since the inside of the chuck can't be accessed.
Еще один человек закончил это руководство.
